Dell Inspiron N4110 Screen Replacement
  1. Dell Inspiron N4110 Screen Replacement, Battery: step 1, image 1 of 1
    • Make sure the laptop is off and unplugged before starting this step.
    • Locate the battery on the underside of the laptop.
    • Push the two battery clips following the direction of the arrows.
  2. Dell Inspiron N4110 Screen Replacement: step 2, image 1 of 1
    • Push upward from the base of the battery.
  3. Dell Inspiron N4110 Screen Replacement: step 3, image 1 of 1
    • Pull battery away from computer until it is fully removed.
  4. Dell Inspiron N4110 Screen Replacement, Screen: step 4, image 1 of 3 Dell Inspiron N4110 Screen Replacement, Screen: step 4, image 2 of 3 Dell Inspiron N4110 Screen Replacement, Screen: step 4, image 3 of 3
    • Use your hands to remove the plastic cover from around the screen.
    • This can seem difficult, but it can be done.
  5. Dell Inspiron N4110 Screen Replacement: step 5, image 1 of 2 Dell Inspiron N4110 Screen Replacement: step 5, image 2 of 2
    • Unscrew the two 2.5x4 mm screws from the top of the screen.
  6. Dell Inspiron N4110 Screen Replacement: step 6, image 1 of 2 Dell Inspiron N4110 Screen Replacement: step 6, image 2 of 2
    • Loosen the four 2.5x4 mm screws from the base of the screen.
    • This will allow the screen to lift from inside the top of the case.
  7. Dell Inspiron N4110 Screen Replacement: step 7, image 1 of 3 Dell Inspiron N4110 Screen Replacement: step 7, image 2 of 3 Dell Inspiron N4110 Screen Replacement: step 7, image 3 of 3
    • Unscrew the four 2x3 mm screws from the two sides on both the top and bottom.
  8. Dell Inspiron N4110 Screen Replacement: step 8, image 1 of 2 Dell Inspiron N4110 Screen Replacement: step 8, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to peel the webcam away from the top of the laptop.
    • The webcam is only held in place by a webcam, this is easy to pull away from the screen.
  9. Dell Inspiron N4110 Screen Replacement: step 9, image 1 of 3 Dell Inspiron N4110 Screen Replacement: step 9, image 2 of 3 Dell Inspiron N4110 Screen Replacement: step 9, image 3 of 3
    • Lift the adhesive flap from the cord that connects the computer to the screen.
    • You can then disconnect the cord from the screen.
  10. Dell Inspiron N4110 Screen Replacement: step 10, image 1 of 1
    • The screen can now be fully removed from the computer.
Abigail Keith
523 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 5
All Time: 1,320
