Dell Inspiron N5010 Hard Drive Replacement
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
  1. Dell Inspiron N5010 Hard Drive Replacement, Remove the Screws: step 2, image 1 of 1
    • Remove the four screws that secure the hard-drive assembly.
  2. Dell Inspiron N5010 Hard Drive Replacement, Lifting the Hard Drive Assembly: step 3, image 1 of 1
    • Turn the computer over and lift the hard-drive assembly out of the hard-drive bay to disconnect the hard-drive assembly from the connector on the system board.
  3. Dell Inspiron N5010 Hard Drive Replacement, Disconnect the Interposer: step 4, image 1 of 1
    • Pull the interposer to disconnect it from the hard drive.
  4. Dell Inspiron N5010 Hard Drive Replacement, Connect the Interposer: step 5, image 1 of 1
    • Connect the interposer to the NEW hard drive.
  5. Dell Inspiron N5010 Hard Drive Replacement, Align the Hard Drive Assembly: step 6, image 1 of 1
    • Align the hard-drive assembly with the connector on the system board and press the hard-drive assembly into the hard-drive bay until it is fully seated.
  6. Dell Inspiron N5010 Hard Drive Replacement, Replace the Screws: step 7, image 1 of 1
    • Turn the computer over and replace the four screws that secure the hard-drive assembly.
Finish Line
Terrence15
79,243 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 17
All Time: 1,940
