Dell Inspiron N5010 Memory Modules Replacement
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer)
    • CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory module securing clips.
  1. Dell Inspiron N5010 Memory Modules Replacement, Popping up the Memory Module: step 2, image 1 of 2 Dell Inspiron N5010 Memory Modules Replacement, Popping up the Memory Module: step 2, image 2 of 2
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the module pops up.
  2. Dell Inspiron N5010 Memory Modules Replacement, Remove the Memory Module: step 3, image 1 of 1
    • Remove the memory module from the memory-module connector.
  3. Dell Inspiron N5010 Memory Modules Replacement, Align the Notch: step 4, image 1 of 2 Dell Inspiron N5010 Memory Modules Replacement, Align the Notch: step 4, image 2 of 2
    • Align the notch in the NEW memory module with the tab in the memory-module connector.
  4. Dell Inspiron N5010 Memory Modules Replacement, Install the Memory Module: step 5, image 1 of 1
    • Slide the memory module firmly into the connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
Finish Line
Terrence15
79,309 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,984 Guides authored
One Comment
I have dell Inspiron n5010 laptop with 2gb ram(2gb 1R*8 PC3-10600s-09-11-B2).I need to upgrade ram to 8gb.suggest me exact ram which supports my laptop.if you suggest the buying link,it would be more helpful to me.
Babu j Ramaswamy - Reply
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 9
All Time: 674
