Dell Inspiron i3558-5500BLK Internal Fan Replacement
  1. Dell Inspiron i3558-5500BLK Internal Fan Replacement, Keyboard: step 1, image 1 of 2 Dell Inspiron i3558-5500BLK Internal Fan Replacement, Keyboard: step 1, image 2 of 2
    • With the laptop open and facing upright, use the Spudger to pull at the notches shown in the image.
  2. Dell Inspiron i3558-5500BLK Internal Fan Replacement: step 2, image 1 of 3 Dell Inspiron i3558-5500BLK Internal Fan Replacement: step 2, image 2 of 3 Dell Inspiron i3558-5500BLK Internal Fan Replacement: step 2, image 3 of 3
    • Gently turn the keyboard over to reveal the ribbon cable underneath. Remove the cable from the motherboard by lifting the white release tab and gently pulling the cable away from the socket.
    • Lift the keyboard away from the baseboard to remove.
  3. Dell Inspiron i3558-5500BLK Internal Fan Replacement, Battery: step 3, image 1 of 3 Dell Inspiron i3558-5500BLK Internal Fan Replacement, Battery: step 3, image 2 of 3 Dell Inspiron i3558-5500BLK Internal Fan Replacement, Battery: step 3, image 3 of 3
    • With the back of the laptop facing upright, press the switch shown to loosen the battery and remove it.
  4. Dell Inspiron i3558-5500BLK Internal Fan Replacement, Back Cover: step 4, image 1 of 2 Dell Inspiron i3558-5500BLK Internal Fan Replacement, Back Cover: step 4, image 2 of 2
    • With the laptop facing upright - remove the ribbon cable from the optical drive by lifting the white release tab and gently pulling the cable away from the socket.
  5. Dell Inspiron i3558-5500BLK Internal Fan Replacement: step 5, image 1 of 2 Dell Inspiron i3558-5500BLK Internal Fan Replacement: step 5, image 2 of 2
    • Slide the optical drive out of the port on the right-side of the laptop.
  6. Dell Inspiron i3558-5500BLK Internal Fan Replacement: step 6, image 1 of 3 Dell Inspiron i3558-5500BLK Internal Fan Replacement: step 6, image 2 of 3 Dell Inspiron i3558-5500BLK Internal Fan Replacement: step 6, image 3 of 3
    • With the back of the laptop facing upright, remove the following screws:
    • Ten 0.5 mm Phillips screws from the backboard
    • One 0.2 mm Phillips screw from the battery port
    • Three 0.1 mm Phillips screws from the optical drive slot.
  7. Dell Inspiron i3558-5500BLK Internal Fan Replacement: step 7, image 1 of 2 Dell Inspiron i3558-5500BLK Internal Fan Replacement: step 7, image 2 of 2
    • Gently pry the back cover from the opposite side of the battery to reveal the internal components.
  8. Dell Inspiron i3558-5500BLK Internal Fan Replacement, Internal Fan: step 8, image 1 of 3 Dell Inspiron i3558-5500BLK Internal Fan Replacement, Internal Fan: step 8, image 2 of 3 Dell Inspiron i3558-5500BLK Internal Fan Replacement, Internal Fan: step 8, image 3 of 3
    • Identify the fan assembly as shown in the image.
    • Remove the power cable by gently pulling it away from the fixture.
  9. Dell Inspiron i3558-5500BLK Internal Fan Replacement: step 9, image 1 of 2 Dell Inspiron i3558-5500BLK Internal Fan Replacement: step 9, image 2 of 2
    • Loosen the three 2 mm Phillips heatsink screws.
    • Remove the 0.5 mm Phillips fastener screw, identified by the red circle.
    • Remove the fan from the motherboard.
  10. Dell Inspiron i3558-5500BLK Internal Fan Replacement: step 10, image 1 of 3 Dell Inspiron i3558-5500BLK Internal Fan Replacement: step 10, image 2 of 3 Dell Inspiron i3558-5500BLK Internal Fan Replacement: step 10, image 3 of 3
    • Unfasten the screws shown in the image to remove the cover and heatsink from the fan unit.
Nathan Ybanez
622 Reputation
6 Guides authored
Cal Poly, Team S9-G5, Banghart Fall 2017 Member of Cal Poly, Team S9-G5, Banghart Fall 2017
CPSU-BANGHART-F17S9G5
4 Members
19 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 397
