Dell Inspiron i3558-5500BLK Keyboard Replacement
Nathan Ybanez
Nathan Ybanez and 4 other contributors
Last updated on July 20, 2024
5 minutes
Easy
Introduction
Go to step 1
This guide will show you how to remove and replace the keyboard for the Dell Inspiron i3558-5500 BLK Laptop.
WARNING: Static electricity can damage the electronic components of this model. Before
beginning these procedures, discharge any built up static electricity by briefly touching a grounded
metal object. For example, you can touch the metal frame inside the case of most desktop computers, or wear an anti-static wristband.
Tools
  • Spudger
    Spudger
  1. Dell Inspiron i3558-5500BLK Keyboard Replacement, Keyboard: step 1, image 1 of 2 Dell Inspiron i3558-5500BLK Keyboard Replacement, Keyboard: step 1, image 2 of 2
    • With the laptop open and facing upright, use the Spudger to pull at the notches shown in the image.
  2. Dell Inspiron i3558-5500BLK Keyboard Replacement: step 2, image 1 of 3 Dell Inspiron i3558-5500BLK Keyboard Replacement: step 2, image 2 of 3 Dell Inspiron i3558-5500BLK Keyboard Replacement: step 2, image 3 of 3
    • Gently turn the keyboard over to reveal the ribbon cable underneath. Remove the cable from the motherboard by lifting the white release tab and gently pulling the cable away from the socket.
    • Lift the keyboard away from the baseboard to remove.
Nathan Ybanez
622 Reputation
6 Guides authored
Cal Poly, Team S9-G5, Banghart Fall 2017 Member of Cal Poly, Team S9-G5, Banghart Fall 2017
CPSU-BANGHART-F17S9G5
4 Members
19 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 54
All Time: 3,536
