Dell Inspiron n5050 Hard Drive Replacement
Tyler
Tyler and 7 other contributors
Last updated on July 29, 2024
15 minutes
Moderate
Community-Contributed Guide
Fix Kits
These kits contain all the parts and tools needed to complete this guide.
Parts
Tools
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
Show more…
  1. Dell Inspiron n5050 Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Flip your laptop over to view the bottom and locate the two locks.
  2. Dell Inspiron n5050 Hard Drive Replacement: step 2, image 1 of 1
    • Slide the two locks away from each other.
    • Sliding these locks will loosen the battery to allow removal.
  3. Dell Inspiron n5050 Hard Drive Replacement: step 3, image 1 of 2 Dell Inspiron n5050 Hard Drive Replacement: step 3, image 2 of 2
    • Pull battery out of the laptop.
    • Your laptop's battery should be completely removed.
  4. Dell Inspiron n5050 Hard Drive Replacement, Keyboard: step 4, image 1 of 2 Dell Inspiron n5050 Hard Drive Replacement, Keyboard: step 4, image 2 of 2
    • Flip the laptop right side up. Open the laptop.
    • Gently press in the four retaining tabs along the top of the keyboard with a spudger, one at a time.
    • After the first tab is released, gently lift up on the keyboard so it doesn't lock again. Finish the other three tabs while gently lifting up on the keyboard. The keyboard will hinge up along the bottom.
  5. Dell Inspiron n5050 Hard Drive Replacement: step 5, image 1 of 3 Dell Inspiron n5050 Hard Drive Replacement: step 5, image 2 of 3 Dell Inspiron n5050 Hard Drive Replacement: step 5, image 3 of 3
    • Gently flip the data cable latch away from the data cable with flat side of spudger.
    • Lift the cable up and out.
    • When reinstalling cable, there are two retainer wings on the sides of the cable that the cable that lock onto the bottom of the cable latch area. When these are in place the cable is properly inserted.
    • For removing the optical drive you don't need to disconnect the keyboard ribbon cable.
    What do I do is i broke the cable retainer wings and the black thing?
    Wezley Joao Ferreira - Reply
    If the connector on the motherboard is still attached and only the clip is broken you can try and find a new clip, or perhaps tape the keyboard in place with electrical tape.
    Tyler - Reply
    I didn’t need to disconnect and remove the cable. I simply set the keyboard gently to the side. This gave me full access to the two RAM module slots for replacement. Hopefully this will make the procedure easier.
    Clemmitt Sigler - Reply
  6. Dell Inspiron n5050 Hard Drive Replacement, Upper Case: step 6, image 1 of 1
    • Close the lid, flip the laptop bottom side up with the battery at the top.
    • Remove the 11 screws holding the upper case to the lower case.
  7. Dell Inspiron n5050 Hard Drive Replacement: step 7, image 1 of 1
    • Flip the laptop over and open the lid.
    • Remove the two screws from the upper case.
  8. Dell Inspiron n5050 Hard Drive Replacement: step 8, image 1 of 3 Dell Inspiron n5050 Hard Drive Replacement: step 8, image 2 of 3 Dell Inspiron n5050 Hard Drive Replacement: step 8, image 3 of 3
    • Gently unplug the power cable.
    • You lift up on the dark gray latch.
    • Pull the blue ribbon up.
    • Gently unplug the touchpad cable.
    • Lift up on the dark gray latch.
  9. Dell Inspiron n5050 Hard Drive Replacement: step 9, image 1 of 1
    • Grab the metal frame of the upper case and gently pull it away from the lower case. Disconnect the cable that says MB before removing the palmrest.
    • Work your way around the perimeter of the upper case.
    Thanks publishing this repair guide.
    Jay - Reply
43 other people completed this guide.
Tyler
5,031 Reputation
16 Guides authored
TechForce Member of TechForce
Business
2 Members
29 Guides authored
10 Comments
Awesome guide! Thank you so much for posting this.
Chris Baines - Reply
My issue was that hard drive slipped out of it connector. Snapped it back in. Works! Thanks for great instructions.
Joe B - Reply
Thanks for your help - now reformattting in a different laptop
rosen220462 - Reply
I've replaced my drive as described above.
Can anyone tell me what comes next?
*I turned it on, got dialog on the drive recognized, but I couldn't get it started.
I did try the dell drivers & utilities that came with it with no luck.
I looked into the options under F2, F8 & F12.
No luck there.
I'm still digging through e-how links.
Sage - Reply
A new hard drive normally doesn't have Windows installed on it. Hopefully you have created the dell recovery dvds when you first obtained the laptop. If you don't have that you can try and download the dvd image from Microsoft at http://www.microsoft.com/en-us/software-....
Tyler -
I have model N4050, so slightly different positions for screw and HDD but, success! New SSD, clone of system, in place and working fine! Thank you very much for the nice work!
Milton - Reply
My Keyboard Didn't Come Off. Only This Little Frame That looks like a dust protector. HELP!!!
SPP3000 - Reply
Can you post a picture somewhere and the link here?
Tyler -
The guide stopped right before accessing and removing the hard drive. I am trying to figure out how to get the hard drive out without breaking any thing. I really hope all the ribbon cables are still okay. I have removed/installed many a hard drive.memory, cards (etc.) but this is my first with a laptop. I thought the Ipod was tough.
Cliff Kononen - Reply
Forgot to mention the screws holding the hd in place
hybrid_tor - Reply
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 50
All Time: 67,055
