Dell Latitude 10-ST2e Front Facing Camera Replacement
  1. Dell Latitude 10-ST2e Front Facing Camera Replacement, Front Facing Camera: step 1, image 1 of 3 Dell Latitude 10-ST2e Front Facing Camera Replacement, Front Facing Camera: step 1, image 2 of 3 Dell Latitude 10-ST2e Front Facing Camera Replacement, Front Facing Camera: step 1, image 3 of 3
    • Using the blue opening tool, separate the back plastic cover from the device. Start in a corner, and work your way around the tablet.
  2. Dell Latitude 10-ST2e Front Facing Camera Replacement: step 2, image 1 of 2 Dell Latitude 10-ST2e Front Facing Camera Replacement: step 2, image 2 of 2
    • Using a JIS #00 screwdriver, remove the one 4.0mm screw securing the camera to the motherboard.
  3. Dell Latitude 10-ST2e Front Facing Camera Replacement: step 3, image 1 of 2 Dell Latitude 10-ST2e Front Facing Camera Replacement: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Use an opening tool to release the black clamp. With the tweezers gently lift and disconnect the motherboad from the camera.
  4. Dell Latitude 10-ST2e Front Facing Camera Replacement: step 4, image 1 of 2 Dell Latitude 10-ST2e Front Facing Camera Replacement: step 4, image 2 of 2
    • Gently lift up the camera using the plastic opening tool and remove it from the tablet.
Khawja
258 Reputation
2 Guides authored
USF Tampa, Team S16-G4, Eyestone Fall 2017 Member of USF Tampa, Team S16-G4, Eyestone Fall 2017
USFT-EYESTONE-F17S16G4
4 Members
13 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 237
