Introduction
If the keyboard for your Dell Latitude 3189 is unresponsive or has broken keys, you may want to replace the keyboard.
Before replacing the keyboard you will need to remove the base cover in order to access the push holes inside of the laptop.
The ribbon keyboard connector can damage easily, be careful when removing the ribbon cable as to not break the connector socket.
Use a Phillips screwdriver to loosen the seven captive screws that secure the lower case.
Flip up the black lock bar on the ZIF connector with a plastic spudger.
Gently pull the ribbon cable directly out of its socket.
