Dell Latitude 3190 Base Cover Replacement
  1. Dell Latitude 3190 Base Cover Replacement, Base Cover: step 1, image 1 of 2 Dell Latitude 3190 Base Cover Replacement, Base Cover: step 1, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the seven 7 mm screws securing the back case.
  2. Dell Latitude 3190 Base Cover Replacement: step 2, image 1 of 3 Dell Latitude 3190 Base Cover Replacement: step 2, image 2 of 3 Dell Latitude 3190 Base Cover Replacement: step 2, image 3 of 3
    • Using a plastic opening tool carefully separate the plastic base cover from the rest of the laptop.
    • Lift the bottom cover from the laptop.
Sean Gherkins
292 Reputation
2 Guides authored
Gateway, Team 1-5, Saknee Fall 2021 Member of Gateway, Team 1-5, Saknee Fall 2021
GCC-SAKNEE-F21S1G5
3 Members
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 14
All Time: 336
