Dell Latitude 3190 Motherboard Replacement
  1. Dell Latitude 3190 Motherboard Replacement, Base Cover: step 1, image 1 of 2 Dell Latitude 3190 Motherboard Replacement, Base Cover: step 1, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the seven 7 mm screws securing the back case.
  2. Dell Latitude 3190 Motherboard Replacement: step 2, image 1 of 3 Dell Latitude 3190 Motherboard Replacement: step 2, image 2 of 3 Dell Latitude 3190 Motherboard Replacement: step 2, image 3 of 3
    • Using a plastic opening tool carefully separate the plastic base cover from the rest of the laptop.
    • Lift the bottom cover from the laptop.
  3. Dell Latitude 3190 Motherboard Replacement, Battery: step 3, image 1 of 1
    • Locate the battery.
  4. Dell Latitude 3190 Motherboard Replacement: step 4, image 1 of 3 Dell Latitude 3190 Motherboard Replacement: step 4, image 2 of 3 Dell Latitude 3190 Motherboard Replacement: step 4, image 3 of 3
    • Disconnect the battery cable located on the top of the battery.
    • Use the spudger and disconnect the battery cable.
    • Pull the cable out of the way.
  5. Dell Latitude 3190 Motherboard Replacement: step 5, image 1 of 3 Dell Latitude 3190 Motherboard Replacement: step 5, image 2 of 3 Dell Latitude 3190 Motherboard Replacement: step 5, image 3 of 3
    • Use a Phillips #0 screwdriver to remove the three 3 mm screws from the battery.
  6. Dell Latitude 3190 Motherboard Replacement: step 6, image 1 of 3 Dell Latitude 3190 Motherboard Replacement: step 6, image 2 of 3 Dell Latitude 3190 Motherboard Replacement: step 6, image 3 of 3
    • Pull the black battery tap upwards to remove the battery.
    • The battery adhesive is strong, do not be afraid to use force. You may need to use the spudger or opening tool as a wedge.
  7. Dell Latitude 3190 Motherboard Replacement, M.2 SSD: step 7, image 1 of 3 Dell Latitude 3190 Motherboard Replacement, M.2 SSD: step 7, image 2 of 3 Dell Latitude 3190 Motherboard Replacement, M.2 SSD: step 7, image 3 of 3
    • Use a spudger to disconnect the battery cable from the motherboard located at the top of the battery.
  8. Dell Latitude 3190 Motherboard Replacement: step 8, image 1 of 3 Dell Latitude 3190 Motherboard Replacement: step 8, image 2 of 3 Dell Latitude 3190 Motherboard Replacement: step 8, image 3 of 3
    • Locate the M.2 SSD after the battery is removed
    • Use the Phillips #0 screwdriver to remove the 3 mm screw from the SSD.
    • Pull the M.2 SSD from the board.
  9. Dell Latitude 3190 Motherboard Replacement, Motherboard: step 9, image 1 of 3 Dell Latitude 3190 Motherboard Replacement, Motherboard: step 9, image 2 of 3 Dell Latitude 3190 Motherboard Replacement, Motherboard: step 9, image 3 of 3
    • Remove the motherboard cable by pulling up on the black bar and carefully removing the blue ribbon cable.
    • Disconnect the white speaker cable connector.
  10. Dell Latitude 3190 Motherboard Replacement: step 10, image 1 of 2 Dell Latitude 3190 Motherboard Replacement: step 10, image 2 of 2
    • Using a spudger, disconnect the black power board and audio cable.
    • Disconnect the white coin cell battery cable.
  11. Dell Latitude 3190 Motherboard Replacement: step 11, image 1 of 3 Dell Latitude 3190 Motherboard Replacement: step 11, image 2 of 3 Dell Latitude 3190 Motherboard Replacement: step 11, image 3 of 3
    • Use the Phillips #0 screwdriver to remove the 3 mm screw and lift the metal bracket that secures the WLAN card on the system board.
    • Disconnect the black and white WLAN cables.
  12. Dell Latitude 3190 Motherboard Replacement: step 12, image 1 of 2 Dell Latitude 3190 Motherboard Replacement: step 12, image 2 of 2
    • Remove the screw that secures the camera cable to the system board.
    • Disconnect camera cable.
    • Disconnect the black sensor cable.
  13. Dell Latitude 3190 Motherboard Replacement: step 13, image 1 of 3 Dell Latitude 3190 Motherboard Replacement: step 13, image 2 of 3 Dell Latitude 3190 Motherboard Replacement: step 13, image 3 of 3
    • Use the Phillips #0 screwdriver to remove the two 3 mm screws from the metal bracket on the display cable.
    • Lift the metal bracket that secures the display cable on the computer.
    • Disconnect the black display cable using a spudger or pull it out by hand.
  14. Dell Latitude 3190 Motherboard Replacement: step 14, image 1 of 3 Dell Latitude 3190 Motherboard Replacement: step 14, image 2 of 3 Dell Latitude 3190 Motherboard Replacement: step 14, image 3 of 3
    • Disconnect the white power connector.
    • Use the spudger to lift up on black bar to release the trackpad ribbon cable.
    • Pull the blue tab release to the cable from the connector.
  15. Dell Latitude 3190 Motherboard Replacement: step 15, image 1 of 3 Dell Latitude 3190 Motherboard Replacement: step 15, image 2 of 3 Dell Latitude 3190 Motherboard Replacement: step 15, image 3 of 3
    • Use a Phillips #0 tp remove the two 3 mm screws on the metal bracket that secures the board.
    • Remove the metal bracket.
  16. Dell Latitude 3190 Motherboard Replacement: step 16, image 1 of 3 Dell Latitude 3190 Motherboard Replacement: step 16, image 2 of 3 Dell Latitude 3190 Motherboard Replacement: step 16, image 3 of 3
    • Use the Phillips #0 screwdriver to remove the five 3 mm screws that secure the motherboard.
  17. Dell Latitude 3190 Motherboard Replacement: step 17, image 1 of 3 Dell Latitude 3190 Motherboard Replacement: step 17, image 2 of 3 Dell Latitude 3190 Motherboard Replacement: step 17, image 3 of 3
    • Carefully lift the motherboard up to remove it from the computer.
    • Make sure not to snag any of the other cables.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Sean Gherkins
292 Reputation
2 Guides authored
Gateway, Team 1-5, Saknee Fall 2021 Member of Gateway, Team 1-5, Saknee Fall 2021
GCC-SAKNEE-F21S1G5
3 Members
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 22
Past 30 Days: 41
All Time: 1,459
