Dell Latitude 3380 Display Assembly Replacement
  1. Dell Latitude 3380 Display Assembly Replacement, Back Cover: step 1, image 1 of 2 Dell Latitude 3380 Display Assembly Replacement, Back Cover: step 1, image 2 of 2
    • Turn the laptop over so that the back is facing up.
    • Remove the nine 3 mm screws with a Phillips #0 screwdriver.
  2. Dell Latitude 3380 Display Assembly Replacement: step 2, image 1 of 2 Dell Latitude 3380 Display Assembly Replacement: step 2, image 2 of 2
    • Use an opening tool to pry the back cover away from the laptop.
  3. Dell Latitude 3380 Display Assembly Replacement, Display Assembly: step 3, image 1 of 3 Dell Latitude 3380 Display Assembly Replacement, Display Assembly: step 3, image 2 of 3 Dell Latitude 3380 Display Assembly Replacement, Display Assembly: step 3, image 3 of 3
    • Remove the single 3 mm screw from the metal bracket using a Phillips #0 screwdriver.
    • Remove the metal bracket.
    • Use a spudger to gently detach the connector from the motherboard.
  4. Dell Latitude 3380 Display Assembly Replacement: step 4, image 1 of 3 Dell Latitude 3380 Display Assembly Replacement: step 4, image 2 of 3 Dell Latitude 3380 Display Assembly Replacement: step 4, image 3 of 3
    • Remove the two 3 mm screws (four total) from both sides of the laptop using a Phillips #0 screwdriver.
    • Lift up the bottom part of the laptop to separate the display assembly from the rest of the laptop.
Michael Wood
377 Reputation
3 Guides authored
Gateway, Team 1-3, Pee Fall 2021 Member of Gateway, Team 1-3, Pee Fall 2021
GCC-PEE-F21S1G3
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 469
