Dell Latitude 3380 Fan Replacement
  1. Dell Latitude 3380 Fan Replacement, Back Cover: step 1, image 1 of 2 Dell Latitude 3380 Fan Replacement, Back Cover: step 1, image 2 of 2
    • Turn the laptop over so that the back is facing up.
    • Remove the nine 3 mm screws with a Phillips #0 screwdriver.
  2. Dell Latitude 3380 Fan Replacement: step 2, image 1 of 2 Dell Latitude 3380 Fan Replacement: step 2, image 2 of 2
    • Use an opening tool to pry the back cover away from the laptop.
  3. Dell Latitude 3380 Fan Replacement, Fan: step 3, image 1 of 1
    • Remove the two 5 mm screws from the fan using a Phillips #0 screwdriver.
  4. Dell Latitude 3380 Fan Replacement: step 4, image 1 of 1
    • Loosen the four captive screws on the heatsink using a Phillips #0 screwdriver.
  5. Dell Latitude 3380 Fan Replacement: step 5, image 1 of 1
    • Remove the heatsink from the motherboard.
  6. Dell Latitude 3380 Fan Replacement: step 6, image 1 of 2 Dell Latitude 3380 Fan Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Using tweezers, loosen the power connector from the fan to the motherboard, fully disconnecting the fan.
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 94
