Dell Latitude 3380 Front Camera Replacement
  1. Dell Latitude 3380 Front Camera Replacement, Back Cover: step 1, image 1 of 2 Dell Latitude 3380 Front Camera Replacement, Back Cover: step 1, image 2 of 2
    • Turn the laptop over so that the back is facing up.
    • Remove the nine 3 mm screws with a Phillips #0 screwdriver.
  2. Dell Latitude 3380 Front Camera Replacement: step 2, image 1 of 2 Dell Latitude 3380 Front Camera Replacement: step 2, image 2 of 2
    • Use an opening tool to pry the back cover away from the laptop.
  3. Dell Latitude 3380 Front Camera Replacement, Front Camera: step 3, image 1 of 2 Dell Latitude 3380 Front Camera Replacement, Front Camera: step 3, image 2 of 2
    • Disconnect the cable strip.
  4. Dell Latitude 3380 Front Camera Replacement: step 4, image 1 of 1
    • Detach the power cable connecting the display to the motherboard.
  5. Dell Latitude 3380 Front Camera Replacement: step 5, image 1 of 1
    • Remove the four screws holding the display in place using a Phillips #0 screwdriver.
  6. Dell Latitude 3380 Front Camera Replacement: step 6, image 1 of 2 Dell Latitude 3380 Front Camera Replacement: step 6, image 2 of 2
    • Using your fingers (or an opening tool if necessary), gently pry off the bottom cover on the display.
  7. Dell Latitude 3380 Front Camera Replacement: step 7, image 1 of 2 Dell Latitude 3380 Front Camera Replacement: step 7, image 2 of 2
    • Remove the screw caps, then the screws using a Phillips #0 screwdriver.
    • Remove the plastic outer covering using an opening tool.
  8. Dell Latitude 3380 Front Camera Replacement: step 8, image 1 of 3 Dell Latitude 3380 Front Camera Replacement: step 8, image 2 of 3 Dell Latitude 3380 Front Camera Replacement: step 8, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the front camera by gently pulling it out with a pair of tweezers.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 65
