Dell Latitude 3380 Motherboard Replacement
  1. Dell Latitude 3380 Motherboard Replacement, Back Cover: step 1, image 1 of 2 Dell Latitude 3380 Motherboard Replacement, Back Cover: step 1, image 2 of 2
    • Turn the laptop over so that the back is facing up.
    • Remove the nine 3 mm screws with a Phillips #0 screwdriver.
  2. Dell Latitude 3380 Motherboard Replacement: step 2, image 1 of 2 Dell Latitude 3380 Motherboard Replacement: step 2, image 2 of 2
    • Use an opening tool to pry the back cover away from the laptop.
  3. Dell Latitude 3380 Motherboard Replacement, Motherboard: step 3, image 1 of 3 Dell Latitude 3380 Motherboard Replacement, Motherboard: step 3, image 2 of 3 Dell Latitude 3380 Motherboard Replacement, Motherboard: step 3, image 3 of 3
    • Remove the four 3 mm screws holding the battery in place using a Phillips #0 screwdriver.
    • Disconnect the battery cable by gently pulling it out.
    • Remove the battery.
  4. Dell Latitude 3380 Motherboard Replacement: step 4, image 1 of 3 Dell Latitude 3380 Motherboard Replacement: step 4, image 2 of 3 Dell Latitude 3380 Motherboard Replacement: step 4, image 3 of 3
    • Remove the 3 mm screw from the WLAN card using a Phillips #0 screwdriver.
    • Disconnect and remove the WLAN card.
  5. Dell Latitude 3380 Motherboard Replacement: step 5, image 1 of 3 Dell Latitude 3380 Motherboard Replacement: step 5, image 2 of 3 Dell Latitude 3380 Motherboard Replacement: step 5, image 3 of 3
    • Disconnect the audio cable.
    • Remove the entire audio card piece.
  6. Dell Latitude 3380 Motherboard Replacement: step 6, image 1 of 3 Dell Latitude 3380 Motherboard Replacement: step 6, image 2 of 3 Dell Latitude 3380 Motherboard Replacement: step 6, image 3 of 3
    • Remove the two 5 mm screws from the fan using a Phillips #0 screwdriver.
    • Loosen the four captive screws on the heatsink using a Phillips #0 screwdriver.
    • Remove the heatsink from the motherboard.
  7. Dell Latitude 3380 Motherboard Replacement: step 7, image 1 of 2 Dell Latitude 3380 Motherboard Replacement: step 7, image 2 of 2
    Tool used on this step:
    Buy
    • Using tweezers, loosen the power connector from the fan to the motherboard, fully disconnecting the fan.
  8. Dell Latitude 3380 Motherboard Replacement: step 8, image 1 of 3 Dell Latitude 3380 Motherboard Replacement: step 8, image 2 of 3 Dell Latitude 3380 Motherboard Replacement: step 8, image 3 of 3
    • Using a Phillips #0 screwdriver, unscrew and remove this metal plate.
    • Gently disconnect the cable under the metal plate.
  9. Dell Latitude 3380 Motherboard Replacement: step 9, image 1 of 2 Dell Latitude 3380 Motherboard Replacement: step 9, image 2 of 2
    • Disconnect the battery power cable.
  10. Dell Latitude 3380 Motherboard Replacement: step 10, image 1 of 2 Dell Latitude 3380 Motherboard Replacement: step 10, image 2 of 2
    • Disconnect the power cable that connects to the charging port.
  11. Dell Latitude 3380 Motherboard Replacement: step 11, image 1 of 2 Dell Latitude 3380 Motherboard Replacement: step 11, image 2 of 2
    • Disconnect the touchpad cable.
  12. Dell Latitude 3380 Motherboard Replacement: step 12, image 1 of 2 Dell Latitude 3380 Motherboard Replacement: step 12, image 2 of 2
    • Remove the five screws from the motherboard using a Phillips #0 screwdriver.
    • Remove the motherboard.
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 22
All Time: 310
