Dell Latitude 3380 Speakers Replacement
  1. Dell Latitude 3380 Speakers Replacement, Back Cover: step 1, image 1 of 2 Dell Latitude 3380 Speakers Replacement, Back Cover: step 1, image 2 of 2
    • Turn the laptop over so that the back is facing up.
    • Remove the nine 3 mm screws with a Phillips #0 screwdriver.
  2. Dell Latitude 3380 Speakers Replacement: step 2, image 1 of 2 Dell Latitude 3380 Speakers Replacement: step 2, image 2 of 2
    • Use an opening tool to pry the back cover away from the laptop.
  3. Dell Latitude 3380 Speakers Replacement, Speakers: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Using tweezers, disconnect the power cable connecting the speakers to the motherboard.
  4. Dell Latitude 3380 Speakers Replacement: step 4, image 1 of 1
    • Using the nylon spudger, pry off the velcro straps attaching the cable to the chassis.
    • The metal spudger is used in the photo, but please use the nylon one as it is ESD safe.
  5. Dell Latitude 3380 Speakers Replacement: step 5, image 1 of 1
    • Using the spudger, pry off the other velcro strap attaching the power cable to the chassis.
  6. Dell Latitude 3380 Speakers Replacement: step 6, image 1 of 1
    • Using your fingers, unhook the last part of the cable from this metal hook.
  7. Dell Latitude 3380 Speakers Replacement: step 7, image 1 of 1
    • Gently lift the speakers from the chassis.
    • They will be attached via velcro to it so you should have some resistance. This is normal.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 85
