Dell Latitude 3380 Touchpad Replacement
  1. Dell Latitude 3380 Touchpad Replacement, Back Cover: step 1, image 1 of 2 Dell Latitude 3380 Touchpad Replacement, Back Cover: step 1, image 2 of 2
    • Turn the laptop over so that the back is facing up.
    • Remove the nine 3 mm screws with a Phillips #0 screwdriver.
  2. Dell Latitude 3380 Touchpad Replacement: step 2, image 1 of 2 Dell Latitude 3380 Touchpad Replacement: step 2, image 2 of 2
    • Use an opening tool to pry the back cover away from the laptop.
  3. Dell Latitude 3380 Touchpad Replacement, Battery: step 3, image 1 of 3 Dell Latitude 3380 Touchpad Replacement, Battery: step 3, image 2 of 3 Dell Latitude 3380 Touchpad Replacement, Battery: step 3, image 3 of 3
    • Remove the three 3 mm screws using a Phillips #0 screwdriver
    • Disconnect the the cable connected to the battery using a spudger.
    • Lift up on the outer edges of the battery to remove it from the laptop.
  4. Dell Latitude 3380 Touchpad Replacement, Touchpad: step 4, image 1 of 3 Dell Latitude 3380 Touchpad Replacement, Touchpad: step 4, image 2 of 3 Dell Latitude 3380 Touchpad Replacement, Touchpad: step 4, image 3 of 3
    • Unplug the touchpad cable using a spudger.
    • Remove the seven screws with a Phillips #0 screwdriver.
    • Remove the metal plate and place it to the side.
  5. Dell Latitude 3380 Touchpad Replacement: step 5, image 1 of 2 Dell Latitude 3380 Touchpad Replacement: step 5, image 2 of 2
    • Remove the three screws with the Phillips #0 screwdriver.
    • Remove the touchpad from the laptop.
Cristofer
169 Reputation
2 Guides authored
Gateway, Team 1-3, Pee Fall 2021 Member of Gateway, Team 1-3, Pee Fall 2021
GCC-PEE-F21S1G3
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 298
