Dell Latitude 3450 RAM Replacement
Video Overview
  1. Dell Latitude 3450 RAM Replacement, Getting Started: step 1, image 1 of 2 Dell Latitude 3450 RAM Replacement, Getting Started: step 1, image 2 of 2
    • Ensure the laptop is powered off .
    • Flip the laptop over.
  2. Dell Latitude 3450 RAM Replacement, Removing the Rear Cover: step 2, image 1 of 3 Dell Latitude 3450 RAM Replacement, Removing the Rear Cover: step 2, image 2 of 3 Dell Latitude 3450 RAM Replacement, Removing the Rear Cover: step 2, image 3 of 3
    • Loosen the two Phillips head screws.
    • These screws should back out, but should not actually be removable.
    • Locate the indent on the rear cover half way between the two Phillips head screws.
    • Insert your spudger to help pry up the rear cover.
    • It may be necessary to run the spudger along the side with the indent to help release the clips
    • Lift off the rear cover.
  3. Dell Latitude 3450 RAM Replacement, Installing the RAM: step 3, image 1 of 3 Dell Latitude 3450 RAM Replacement, Installing the RAM: step 3, image 2 of 3 Dell Latitude 3450 RAM Replacement, Installing the RAM: step 3, image 3 of 3
    • The RAM slots are in line with the hard drive, and on the right side if the cover was opened away from you.
    • Please note that there are A and B RAM Slots. There must be a RAM chip in the A Slot, or the laptop will not load normally.
    • The Slots are labeled on the board, under where the chips would normally be seated.
    • Ensure that the space in the RAM chip lines up with alignment pin on the slot.
    • Insert the RAM chip at approximately at 45° angle.
    • Once the chip bottoms out on the slot, push down on the opposite side from the pins until the RAM chip seats on the board.
    • Depending on your machines current configuration, you may need to remove a RAM chip before you can insert your new ones.
    • Using your finger nail or a spudger, push the lock clips off the RAM chip.
    • Normally the clips can be done one at a time, but may require you to release both at once.
    • Once released, the chip should spring up and can be removed.
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 42
All Time: 3,372
