Dell Latitude 3500 System Fan Replacement
  1. Dell Latitude 3500 System Fan Replacement, Remove screws: step 1, image 1 of 1
    • 10 screws hold the bottom cover in place -- these stay in the bottom cover.
  2. Dell Latitude 3500 System Fan Replacement, Separate bottom cover and palmrest: step 2, image 1 of 1
    • Using a spudger will make quick work of this step.
  3. Dell Latitude 3500 System Fan Replacement, Disconnect and Remove Battery: step 3, image 1 of 1
    • Disconnect the battery cable from the motherboard.
    • Remove the 4 screws holding it in place
    • Battery can now be removed from device.
  4. Dell Latitude 3500 System Fan Replacement, Disconnect Surrounding Connections from System Fan: step 4, image 1 of 1
    • Unplug the fan header
    • Unplug the VGA board cable
    • Unplug the LCD cable
  5. Dell Latitude 3500 System Fan Replacement, Remove Fan Screws: step 5, image 1 of 1
    • Once these 2 screws are removed the fan will lift out as long as the cables are out of the way.
Jake
1,327 Reputation
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 133
