Dell Latitude 3500 WLAN Card Replacement
  1. Dell Latitude 3500 WLAN Card Replacement, Remove screws: step 1, image 1 of 1
    • 10 screws hold the bottom cover in place -- these stay in the bottom cover.
  2. Dell Latitude 3500 WLAN Card Replacement, Separate bottom cover and palmrest: step 2, image 1 of 1
    • Using a spudger will make quick work of this step.
  3. Dell Latitude 3500 WLAN Card Replacement, Disconnect and Remove Battery: step 3, image 1 of 1
    • Disconnect the battery cable from the motherboard.
    • Remove the 4 screws holding it in place
    • Battery can now be removed from device.
  4. Dell Latitude 3500 WLAN Card Replacement, Unscrew Bracket: step 4, image 1 of 1
    • Holds down card and keeps antenna in place
  5. Dell Latitude 3500 WLAN Card Replacement, Disconnect Antennas: step 5, image 1 of 1
    • Carefully remove the two antennas from their slots.
    • The card should slide right out for easy replacement.
Jake
1,327 Reputation
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 78
