Dell Latitude 3520 Bottom Case Replacement
  1. Dell Latitude 3520 Bottom Case Replacement, Bottom Case: step 1, image 1 of 3 Dell Latitude 3520 Bottom Case Replacement, Bottom Case: step 1, image 2 of 3 Dell Latitude 3520 Bottom Case Replacement, Bottom Case: step 1, image 3 of 3
    • Loosen the nine screws 2mm Phillips #0 that secure the base cover to the assembly.
    • Using a plastic scribe, pry open the base cover starting from the recesses located in the indents near the hinges at the top edge of the base cover.
    • Carefully lift and remove the base cover.
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 22
All Time: 119
