Dell Latitude 3520 RAMReplacement
  1. Dell Latitude 3520 RAMReplacement, Remove MicroSD-card: step 1, image 1 of 1
    • Push the microSD-card to eject it from the slot.
    • Remove the microSD-card from the computer.
  2. Dell Latitude 3520 RAMReplacement, Bottom Case: step 2, image 1 of 3 Dell Latitude 3520 RAMReplacement, Bottom Case: step 2, image 2 of 3 Dell Latitude 3520 RAMReplacement, Bottom Case: step 2, image 3 of 3
    • Loosen the nine screws 2mm Phillips #0 that secure the base cover to the assembly.
    • Using a plastic scribe, pry open the base cover starting from the recesses located in the indents near the hinges at the top edge of the base cover.
    • Carefully lift and remove the base cover.
  3. Dell Latitude 3520 RAMReplacement, RAM: step 3, image 1 of 2 Dell Latitude 3520 RAMReplacement, RAM: step 3, image 2 of 2
    • Lift the clips to find the memory module slot.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 33
All Time: 650
