Dell Latitude 5521 Base Cover Replacement
  1. Dell Latitude 5521 Base Cover Replacement, Base Cover Removal: step 1, image 1 of 3 Dell Latitude 5521 Base Cover Replacement, Base Cover Removal: step 1, image 2 of 3 Dell Latitude 5521 Base Cover Replacement, Base Cover Removal: step 1, image 3 of 3
    • Remove the 9 phillips #0 screws from the bottom of the case.
    • Carefully pry open the base cover with your spudger. Work your way around the case slowly, being careful not to damage any of the components inside.
    • Once removed you will have access to the contents of your case.
Michael Engle
461 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 342
