Dell Latitude 5521 Solid-State Drive Replacement
  1. Dell Latitude 5521 Solid-State Drive Replacement, Base Cover Removal: step 1, image 1 of 3 Dell Latitude 5521 Solid-State Drive Replacement, Base Cover Removal: step 1, image 2 of 3 Dell Latitude 5521 Solid-State Drive Replacement, Base Cover Removal: step 1, image 3 of 3
    • Remove the 9 phillips #0 screws from the bottom of the case.
    • Carefully pry open the base cover with your spudger. Work your way around the case slowly, being careful not to damage any of the components inside.
    • Once removed you will have access to the contents of your case.
  2. Dell Latitude 5521 Solid-State Drive Replacement, Solid-State Drive: step 2, image 1 of 2 Dell Latitude 5521 Solid-State Drive Replacement, Solid-State Drive: step 2, image 2 of 2
    • Locate the solid-state drive.
    • Remove the screw on the right side of the drive.
    • After remove the screw, the drive will "pop-up" to approximately a 45% angle. Pull the drive straight out in accordance with the angle.
    • Static electricity is always a danger. Take precautions to protect the drive while, and once, it is removed.
Michael Engle
461 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 26
All Time: 1,160
