Dell Latitude 6430u Memory chip (RAM) Replacement
    • Shut down your computer. Disconnect all power sources before opening the computer cover or panels.
    • Remove the battery, SD card & base cover from the computer, respectively.
  1. Dell Latitude 6430u Memory chip (RAM) Replacement, Pry open clips; remove memory chip/module from connector.: step 2, image 1 of 1
    • Pry the securing clips away from the memory module until it pops up. Remove the memory module from its connector on the system board.
    • Insert the memory module into the memory socket.
    • Press the memory module down until it clicks into place.
    • Install the base cover, SD card, & battery on the computer, respectively.
Hezekiah Brown
6,169 Reputation
50 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,984 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 20
All Time: 291
