Dell Latitude 7350 Lower Case Replacement
  1. Dell Latitude 7350 Lower Case Replacement, Lower Case: step 1, image 1 of 1
    • Remove the following ten T5 screws securing the lower case to the upper case.
    • Two will be 6mm, eight will be 3mm in length.
  2. Dell Latitude 7350 Lower Case Replacement: step 2, image 1 of 2 Dell Latitude 7350 Lower Case Replacement: step 2, image 2 of 2
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 6
All Time: 58
