Dell Latitude 7350 Touch Screen Replacement
  1. Dell Latitude 7350 Touch Screen Replacement, Touch Screen: step 1, image 1 of 1
    • Push down back-plate of the touch screen
  2. Dell Latitude 7350 Touch Screen Replacement: step 2, image 1 of 3 Dell Latitude 7350 Touch Screen Replacement: step 2, image 2 of 3 Dell Latitude 7350 Touch Screen Replacement: step 2, image 3 of 3
    • Avoid static discharge by grounding yourself using a wrist grounding strap or by touching a bare metal surface like a connector on the back of the laptop. Remove all of the power including the battery and power adapter.
    • Unscrew and remove the battery.
  3. Dell Latitude 7350 Touch Screen Replacement: step 3, image 1 of 3 Dell Latitude 7350 Touch Screen Replacement: step 3, image 2 of 3 Dell Latitude 7350 Touch Screen Replacement: step 3, image 3 of 3
    • Open the cover of the screen.
    • Remove the wide head.
  4. Dell Latitude 7350 Touch Screen Replacement: step 4, image 1 of 2 Dell Latitude 7350 Touch Screen Replacement: step 4, image 2 of 2
    • Take off the screen battery.
    • Remove the following screw.
  5. Dell Latitude 7350 Touch Screen Replacement: step 5, image 1 of 3 Dell Latitude 7350 Touch Screen Replacement: step 5, image 2 of 3 Dell Latitude 7350 Touch Screen Replacement: step 5, image 3 of 3
    • Unscrew and remove SSD from motherboard.
    • Disconnect then unscrew and remove audio circuit board.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 382
