Dell Latitude 7390 Bottom Panel Replacement
  1. Dell Latitude 7390 Bottom Panel Replacement, Bottom Panel: step 1, image 1 of 1
    • Orient your Dell Latitude 7390 laptop so that it is facing towards you as if you're going to open it.
  2. Dell Latitude 7390 Bottom Panel Replacement: step 2, image 1 of 3 Dell Latitude 7390 Bottom Panel Replacement: step 2, image 2 of 3 Dell Latitude 7390 Bottom Panel Replacement: step 2, image 3 of 3
    • Flip your laptop over so that the bottom is facing up.
  3. Dell Latitude 7390 Bottom Panel Replacement: step 3, image 1 of 1
    • Using your Phillips #1 screwdriver, remove the eight 6 mm screws around the border of the bottom panel.
  4. Dell Latitude 7390 Bottom Panel Replacement: step 4, image 1 of 2 Dell Latitude 7390 Bottom Panel Replacement: step 4, image 2 of 2
    • Using an opening tool or picks, work your way around the periphery and pry the back case off.
  5. Dell Latitude 7390 Bottom Panel Replacement: step 5, image 1 of 1
    • Finally, lift the back panel off to uncover the inside of your Dell Latitude 7390.
Julia Blahut
303 Reputation
2 Guides authored
Clemson, Team 1-4, Hunter Spring 2022 Member of Clemson, Team 1-4, Hunter Spring 2022
CLEM-HUNTER-S22S1G4
5 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 39
All Time: 736
