Dell Latitude 7390 Fan Replacement
  1. Dell Latitude 7390 Fan Replacement, Bottom Panel: step 1, image 1 of 1
    • Orient your Dell Latitude 7390 laptop so that it is facing towards you as if you're going to open it.
  2. Dell Latitude 7390 Fan Replacement: step 2, image 1 of 3 Dell Latitude 7390 Fan Replacement: step 2, image 2 of 3 Dell Latitude 7390 Fan Replacement: step 2, image 3 of 3
    • Flip your laptop over so that the bottom is facing up.
  3. Dell Latitude 7390 Fan Replacement: step 3, image 1 of 1
    • Using your Phillips #1 screwdriver, remove the eight 6 mm screws around the border of the bottom panel.
  4. Dell Latitude 7390 Fan Replacement: step 4, image 1 of 2 Dell Latitude 7390 Fan Replacement: step 4, image 2 of 2
    • Using an opening tool or picks, work your way around the periphery and pry the back case off.
  5. Dell Latitude 7390 Fan Replacement: step 5, image 1 of 1
    • Finally, lift the back panel off to uncover the inside of your Dell Latitude 7390.
  6. Dell Latitude 7390 Fan Replacement, Battery: step 6, image 1 of 1
    • Make sure the laptop is turned OFF and unplugged from the power adapter before taking the battery out.
    • Use the Phillips #1 screwdriver to remove the five 6 mm screws holding the battery in place along the edges of the battery.
  7. Dell Latitude 7390 Fan Replacement: step 7, image 1 of 3 Dell Latitude 7390 Fan Replacement: step 7, image 2 of 3 Dell Latitude 7390 Fan Replacement: step 7, image 3 of 3
    • Be careful not to break the connector by pulling too hard on the black tab.
    • Pull the black tab on the top of the connector to unplug the battery from the motherboard.
  8. Dell Latitude 7390 Fan Replacement: step 8, image 1 of 1
    • Carefully lift the battery out of the laptop.
  9. Dell Latitude 7390 Fan Replacement, Fan: step 9, image 1 of 1
    • Remove the five black screws holding the fan and heatsink in place using the Phillips #0 screwdriver.
  10. Dell Latitude 7390 Fan Replacement: step 10, image 1 of 1
    Tool used on this step:
    Buy
    • Use tweezers or your fingers to disconnect the fan connector.
  11. Dell Latitude 7390 Fan Replacement: step 11, image 1 of 1
    • Remove the fan from the case.
3 other people completed this guide.
Glennjay Elayda
246 Reputation
2 Guides authored
Clemson, Team 1-4, Hunter Spring 2022 Member of Clemson, Team 1-4, Hunter Spring 2022
CLEM-HUNTER-S22S1G4
5 Members
7 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 98
All Time: 2,660
