Dell Latitude 7410 Back Cover Replacement
  1. Dell Latitude 7410 Back Cover Replacement, Unfasten the back cover: step 1, image 1 of 1
    • Use a Phillips screwdriver to loosen the eight captive screws securing the back cover.
  2. Dell Latitude 7410 Back Cover Replacement, Insert an opening pick: step 2, image 1 of 2 Dell Latitude 7410 Back Cover Replacement, Insert an opening pick: step 2, image 2 of 2
    • Insert an opening pick between the right edge of the back cover and the frame, just below the middle right screw.
  3. Dell Latitude 7410 Back Cover Replacement, Unclip the right edge: step 3, image 1 of 2 Dell Latitude 7410 Back Cover Replacement, Unclip the right edge: step 3, image 2 of 2
    • Slide your pick along the right edge to release the clips securing the back cover.
  4. Dell Latitude 7410 Back Cover Replacement, Unclip the left edge: step 4, image 1 of 3 Dell Latitude 7410 Back Cover Replacement, Unclip the left edge: step 4, image 2 of 3 Dell Latitude 7410 Back Cover Replacement, Unclip the left edge: step 4, image 3 of 3
    • Insert your pick between the left edge of the back cover and the frame, next to the speaker cutout.
    • Slide your pick along the left edge to release the clips.
  5. Dell Latitude 7410 Back Cover Replacement, Unclip the back edge: step 5, image 1 of 3 Dell Latitude 7410 Back Cover Replacement, Unclip the back edge: step 5, image 2 of 3 Dell Latitude 7410 Back Cover Replacement, Unclip the back edge: step 5, image 3 of 3
    • Insert your pick between the back cover and the right display-hinge to release the first clip along the back edge.
    • Slide your pick toward the left hinge until the second clip releases.
  6. Dell Latitude 7410 Back Cover Replacement, Unclip the front edge: step 6, image 1 of 2 Dell Latitude 7410 Back Cover Replacement, Unclip the front edge: step 6, image 2 of 2
    • Insert your pick between the front edge of the back cover and the frame, just to the right of the bottom left screw.
    • Slide your pick toward the right edge until the front edge releases from the frame.
  7. Dell Latitude 7410 Back Cover Replacement, Remove the back cover: step 7, image 1 of 2 Dell Latitude 7410 Back Cover Replacement, Remove the back cover: step 7, image 2 of 2
    • Remove the back cover.
Clay Eickemeyer
69,529 Reputation
453 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,903 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 16
All Time: 146
