Dell Latitude 7490 Speakers Replacement
  1. Dell Latitude 7490 Speakers Replacement, Prepare your laptop for disassembly: step 1, image 1 of 2 Dell Latitude 7490 Speakers Replacement, Prepare your laptop for disassembly: step 1, image 2 of 2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Dell Latitude 7490 Speakers Replacement, Flip your laptop over: step 2, image 1 of 1
    • Flip your laptop over so the rubber feet strips are facing up.
  3. Dell Latitude 7490 Speakers Replacement, Loosen the captive screws: step 3, image 1 of 2 Dell Latitude 7490 Speakers Replacement, Loosen the captive screws: step 3, image 2 of 2
    • Use a Phillips screwdriver to fully loosen the eight captive screws securing the back cover.
  4. Dell Latitude 7490 Speakers Replacement, Insert an opening pick: step 4, image 1 of 3 Dell Latitude 7490 Speakers Replacement, Insert an opening pick: step 4, image 2 of 3 Dell Latitude 7490 Speakers Replacement, Insert an opening pick: step 4, image 3 of 3
    • Plastic clips secure the back cover to the frame. You'll hear and feel them release as you work.
    • Insert the long side of an opening pick between the top right corner of the back cover and frame.
    • Pry the back cover up to release the clips securing the top right corner.
  5. Dell Latitude 7490 Speakers Replacement, Release the clips: step 5, image 1 of 3 Dell Latitude 7490 Speakers Replacement, Release the clips: step 5, image 2 of 3 Dell Latitude 7490 Speakers Replacement, Release the clips: step 5, image 3 of 3
    • Slide the opening pick down the right edge and around the bottom right corner to release the clips.
  6. Dell Latitude 7490 Speakers Replacement: step 6, image 1 of 3 Dell Latitude 7490 Speakers Replacement: step 6, image 2 of 3 Dell Latitude 7490 Speakers Replacement: step 6, image 3 of 3
    • Slide the opening pick along the front edge and up to the top left corner to release the remaining clips securing the back cover.
  7. Dell Latitude 7490 Speakers Replacement, Remove the back cover: step 7, image 1 of 3 Dell Latitude 7490 Speakers Replacement, Remove the back cover: step 7, image 2 of 3 Dell Latitude 7490 Speakers Replacement, Remove the back cover: step 7, image 3 of 3
    • Remove the back cover.
    • During reassembly, lay the back cover on the frame and press down firmly around the perimeter to engage all the clips.
  8. Dell Latitude 7490 Speakers Replacement, Disconnect the battery: step 8, image 1 of 2 Dell Latitude 7490 Speakers Replacement, Disconnect the battery: step 8, image 2 of 2
    • Grip the plastic tab on the battery connector and pull straight up to disconnect it.
    • During reassembly, align this connector over its socket and press down until it clicks into place. If it doesn't connect, re‑align it and try again.
  9. Dell Latitude 7490 Speakers Replacement, Disconnect the speakers: step 9, image 1 of 3 Dell Latitude 7490 Speakers Replacement, Disconnect the speakers: step 9, image 2 of 3 Dell Latitude 7490 Speakers Replacement, Disconnect the speakers: step 9, image 3 of 3
    • Use clean fingernails to pull the speaker connector out of its socket on motherboard's bottom left corner.
    • If your fingernails aren't long enough, use a spudger to push on alternating sides of the connector and "walk" it out of its socket.
  10. Dell Latitude 7490 Speakers Replacement, Reposition the speaker wire: step 10, image 1 of 3 Dell Latitude 7490 Speakers Replacement, Reposition the speaker wire: step 10, image 2 of 3 Dell Latitude 7490 Speakers Replacement, Reposition the speaker wire: step 10, image 3 of 3
    • Use your fingers to guide the speaker wire out of its clips near the left edge of the battery.
  11. Dell Latitude 7490 Speakers Replacement, Pry up the speakers: step 11, image 1 of 3 Dell Latitude 7490 Speakers Replacement, Pry up the speakers: step 11, image 2 of 3 Dell Latitude 7490 Speakers Replacement, Pry up the speakers: step 11, image 3 of 3
    • The speakers are secured to the frame with rubber grommets.
    • Insert the flat side of an opening pick between the bottom edge of the left speaker and frame.
    • Pry the speaker up to free it from the frame.
    • Use the same process to free the right speaker.
  12. Dell Latitude 7490 Speakers Replacement, Remove the speakers: step 12, image 1 of 2 Dell Latitude 7490 Speakers Replacement, Remove the speakers: step 12, image 2 of 2
    • Remove the speakers.
    • To reinstall a speaker, line the grommets up with their posts in the frame and push the speakers down to secure them.
Spencer Day
95,682 Reputation
662 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,537 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 53
All Time: 388
