Dell Latitude 9510 Base Panel Replacement
Connor
Connor and 4 other contributors
Last updated on January 10, 2025
2 minutes
Easy
Introduction
Go to step 1
This is an in depth instruction manual to replace the baseplate for your Dell Latitude 9510 laptop. The baseplate, also known as a backplate, is used to protect the inner electronics of the computer from small drops and spills. This is a common replacement due to dropping the device or improperly removing the backplate making it break.
Parts
Tools
Show more…
  1. Dell Latitude 9510 Base Panel Replacement, Base Panel: step 1, image 1 of 1
    • Flip the device so that the base plate is facing you.
    • Use a Phillips #0 screwdriver to remove the nine 5.5 mm screws securing the base plate.
  2. Dell Latitude 9510 Base Panel Replacement: step 2, image 1 of 1
    • Wedge a spudger between the base plate and the chassis, then gently pry around the entire perimeter to release the base plate.
    • Remove the base plate.
Connor
12,218 Reputation
64 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,465 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 159
