Dell Latitude 9510 Speakers Replacement
  1. Dell Latitude 9510 Speakers Replacement, Base Panel: step 1, image 1 of 1
    • Flip the device so that the base plate is facing you.
    • Use a Phillips #0 screwdriver to remove the nine 5.5 mm screws securing the base plate.
  2. Dell Latitude 9510 Speakers Replacement: step 2, image 1 of 1
    • Wedge a spudger between the base plate and the chassis, then gently pry around the entire perimeter to release the base plate.
    • Remove the base plate.
  3. Dell Latitude 9510 Speakers Replacement, Speakers: step 3, image 1 of 1
    • Use a Phillips #0 screwdriver to remove the four 2 mm screws from the speakers.
  4. Dell Latitude 9510 Speakers Replacement: step 4, image 1 of 1
    • Use a spudger to gently lever the speaker connector out of its port.
    • Lift the speakers up and out.
David Cauley
169 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 63
