Dell Latitude D430 Keyboard Replacement
  1. Dell Latitude D430 Keyboard Replacement, Keyboard: step 1, image 1 of 1
    • Lay the laptop flat with the screen facing upward. This will allow you to have the most room while performing the keyboard replacement.
  2. Dell Latitude D430 Keyboard Replacement: step 2, image 1 of 2 Dell Latitude D430 Keyboard Replacement: step 2, image 2 of 2
    • Identify the plastic cover located directly below the screen.
    • Carefully remove the plastic cover by lifting both ends of the cover.
    • This piece is very fragile, so be sure not to break this piece. It requires minimal force to remove this piece.
  3. Dell Latitude D430 Keyboard Replacement: step 3, image 1 of 3 Dell Latitude D430 Keyboard Replacement: step 3, image 2 of 3 Dell Latitude D430 Keyboard Replacement: step 3, image 3 of 3
    • There are 3 screws that should be exposed now.
    • Use a Phillips 00 screwdriver to remove all 3 of the screws shown in the pictures.
  4. Dell Latitude D430 Keyboard Replacement: step 4, image 1 of 3 Dell Latitude D430 Keyboard Replacement: step 4, image 2 of 3 Dell Latitude D430 Keyboard Replacement: step 4, image 3 of 3
    • Gently lift the keyboard from the top.
    • At the bottom of the keyboard, there will be ribbons connecting it to the motherboard. Be sure not to tear the ribbons.
    • Lift the clamps that are holding the ribbons in place in order to remove them. You should be able to remove the keyboard at this point.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 419
