Dell Latitude D430 RAM Replacement
  1. Dell Latitude D430 RAM Replacement, RAM: step 1, image 1 of 3 Dell Latitude D430 RAM Replacement, RAM: step 1, image 2 of 3 Dell Latitude D430 RAM Replacement, RAM: step 1, image 3 of 3
    • Flip the laptop so that the battery is facing up, and the Dell logo is facing down on the surface the laptop is placed on.
  2. Dell Latitude D430 RAM Replacement: step 2, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the 3 screws that hold the L-shaped back panel down.
  3. Dell Latitude D430 RAM Replacement: step 3, image 1 of 1
    • Lift the L-shaped panel by the corners, and set it to the side.
  4. Dell Latitude D430 RAM Replacement: step 4, image 1 of 2 Dell Latitude D430 RAM Replacement: step 4, image 2 of 2
    • Pull on the outside tabs keeping the RAM stick in place.
    • The RAM should then pop out and can be easily removed by pulling away from the slot.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 17
All Time: 548
