Dell Latitude D430 Wireless Adapter Replacement
  1. Dell Latitude D430 Wireless Adapter Replacement, Wireless Adapter: step 1, image 1 of 3 Dell Latitude D430 Wireless Adapter Replacement, Wireless Adapter: step 1, image 2 of 3 Dell Latitude D430 Wireless Adapter Replacement, Wireless Adapter: step 1, image 3 of 3
    • Flip the laptop so you are able to see the bottom.
  2. Dell Latitude D430 Wireless Adapter Replacement: step 2, image 1 of 2 Dell Latitude D430 Wireless Adapter Replacement: step 2, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the three screws that secure the small "L" shaped backplate.
  3. Dell Latitude D430 Wireless Adapter Replacement: step 3, image 1 of 1
    • Once all 3 screws have been removed, carefully remove the panel by grabbing the edges, and pulling up.
  4. Dell Latitude D430 Wireless Adapter Replacement: step 4, image 1 of 3 Dell Latitude D430 Wireless Adapter Replacement: step 4, image 2 of 3 Dell Latitude D430 Wireless Adapter Replacement: step 4, image 3 of 3
    • Identify the two pins connecting the wireless adapter to the motherboard. (The wireless adapter will say WLAN on it.)
    • Carefully pull up on each pin and remove them from the wireless adapter.
    • Note that there are no wires/cables connecting the wireless adapter to the motherboard.
  5. Dell Latitude D430 Wireless Adapter Replacement: step 5, image 1 of 2 Dell Latitude D430 Wireless Adapter Replacement: step 5, image 2 of 2
    • Pull back on the two metal tabs holding the wireless adapter down.
    • After the two metal tabs are pulled, the card will pop up.
  6. Dell Latitude D430 Wireless Adapter Replacement: step 6, image 1 of 1
    • Pull the wireless adapter out away from where it was connected.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 511
