Dell Latitude D531 Coin Cell Battery Replacement
    • Shut down your computer. Disconnect all power sources before opening the computer cover or panels.
    • To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching a connector on the back panel of the computer.
    • Remove the battery.
  1. Dell Latitude D531 Coin Cell Battery Replacement, Loosen screw on memory module/coin-cell battery cover.: step 2, image 1 of 1
    • On the bottom of the computer, loosen the captive screw on the memory module/coin-cell battery cover and remove the cover (see image).
  2. Dell Latitude D531 Coin Cell Battery Replacement, Use scribe to lift up coin-cell battery; replace battery.: step 3, image 1 of 1
    • Insert a plastic scribe into the guide on the side of the coin-cell battery compartment, and ease the battery out of the compartment.
    • When you replace the battery, insert it at a 30-degree angle under the clip with the positive (identified by a plus [+] symbol) side up, and then push it into place.
    • Tighten the screw on memory module/coin-cell battery cover.
    • Install the battery.
Hezekiah Brown
6,169 Reputation
50 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 95
