Dell Latitude D531 Keyboard Replacement
    • Shut down your computer. Disconnect all power sources before opening the computer cover or panels.
    • Remove the battery and hinge cover.
  1. Dell Latitude D531 Keyboard Replacement, Remove screw at the top of the keyboard; lift keyboard.: step 2, image 1 of 1
    • Remove the three screws at the top of the keyboard.
    • The keycaps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Be careful when removing and handling the keyboard.
    • Lift the keyboard only enough to hold it up and slightly forward to allow access to the keyboard connector on the system board.
    • To release the keyboard cable from the connector on the system board, rotate the plastic bar on the keyboard connector.
    • To avoid scratching the palm rest when replacing the keyboard, hook the tabs along the front edge of the keyboard into the palm rest, and then secure the keyboard in place.
    • To replace the keyboard, connect the keyboard cable to the connector on the system board.
    • Place the tabs along the front edge of the keyboard into the palm rest, and lay the keyboard down on the palm rest.
    • Replace the three screws at the top of the keyboard.
    • Replace the hinge cover.
    • Install the battery.
Hezekiah Brown
6,169 Reputation
50 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 141
