Dell Latitude D600 Wireless WiFi Card Replacement
Joseph
Joseph and one other contributor
Last updated on August 18, 2014
No estimate
Moderate
Community-Contributed Guide
Introduction
Go to step 1
Replacing the intel wireless card, available for around 5 dollars on ebay
Parts
  1. Dell Latitude D600 Wireless WiFi Card Replacement, Battery: step 1, image 1 of 1
    • Find the battery
  2. Dell Latitude D600 Wireless WiFi Card Replacement: step 2, image 1 of 2 Dell Latitude D600 Wireless WiFi Card Replacement: step 2, image 2 of 2
    • Pull the tab to release the battery
  3. Dell Latitude D600 Wireless WiFi Card Replacement: step 3, image 1 of 1
    • Pull the battery out
  4. Dell Latitude D600 Wireless WiFi Card Replacement, Wireless WiFi Card: step 4, image 1 of 1
    • Use your screwdriver to unscrew and lift up the panel on the right labeled with a C
  5. Dell Latitude D600 Wireless WiFi Card Replacement: step 5, image 1 of 1
    • Pull off the two wires connected to the wireless card
    • They should come off fairly easy
  6. Dell Latitude D600 Wireless WiFi Card Replacement: step 6, image 1 of 2 Dell Latitude D600 Wireless WiFi Card Replacement: step 6, image 2 of 2
    • Pull the two tabs away from the card and pull up on the intel card
    • Then pull it away from the holding slot to remove it
  7. Dell Latitude D600 Wireless WiFi Card Replacement: step 7, image 1 of 2 Dell Latitude D600 Wireless WiFi Card Replacement: step 7, image 2 of 2
    • When placing in your new wireless card, connect the two wires before inserting into the slot
    • Then line it up, put the card in at an angle and push down so the side tabs lock it into place
6 other people completed this guide.
Joseph
1,497 Reputation
5 Guides authored
One Comment
Hi,
dell latitude D600 Laptop
Can you please help me, I cant release my wireless card, by pulling the tabs on cards sides.?
It just doesn't release the card to pull out, is there any other way I can remove my card.?
Email me if you can .
robert.wilson407@ntlworld.com
Thanking you Rob
rob wilson - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 2,708
