Dell Latitude D610 Keyboard Replacement
  1. Dell Latitude D610 Keyboard Replacement, Battery: step 1, image 1 of 2 Dell Latitude D610 Keyboard Replacement, Battery: step 1, image 2 of 2
    • Remove the 3.9 mm Phillips #1 screw from the battery compartment.
  2. Dell Latitude D610 Keyboard Replacement: step 2, image 1 of 3 Dell Latitude D610 Keyboard Replacement: step 2, image 2 of 3 Dell Latitude D610 Keyboard Replacement: step 2, image 3 of 3
    • Locate the laptop battery release button lock
    • Push the battery release in the direction of the arrow, and pull upward.
  3. Dell Latitude D610 Keyboard Replacement: step 3, image 1 of 1
    • Remove the battery from its compartment.
  4. Dell Latitude D610 Keyboard Replacement, Keyboard: step 4, image 1 of 3 Dell Latitude D610 Keyboard Replacement, Keyboard: step 4, image 2 of 3 Dell Latitude D610 Keyboard Replacement, Keyboard: step 4, image 3 of 3
    • Use an opening tool or flat tool to remove the plastic cover above the keyboard.
  5. Dell Latitude D610 Keyboard Replacement: step 5, image 1 of 2 Dell Latitude D610 Keyboard Replacement: step 5, image 2 of 2
    • Remove the two 3.9mm Philips #1 screws that are holding the keyboard in place.
  6. Dell Latitude D610 Keyboard Replacement: step 6, image 1 of 2 Dell Latitude D610 Keyboard Replacement: step 6, image 2 of 2
    • Using an opening tool, carefully release the keyboard from the case.
    • Making sure not to tear or damage the wires still connecting it to the laptop.
  7. Dell Latitude D610 Keyboard Replacement: step 7, image 1 of 3 Dell Latitude D610 Keyboard Replacement: step 7, image 2 of 3 Dell Latitude D610 Keyboard Replacement: step 7, image 3 of 3
    • Carfully lift the key board.
    • Lift only about 3 - 4 inches so that the wires holding the keyboard do not get damaged.
    • Pull on the blue tab to unplug the keyboard.
4 other people completed this guide.
Jordan Barham
459 Reputation
3 Guides authored
Cal Poly, Team 6-24, Maness Winter 2014 Member of Cal Poly, Team 6-24, Maness Winter 2014
CPSU-MANESS-W14S6G24
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 20
All Time: 2,055
