Dell Latitude D610 Modem Replacement
  1. Dell Latitude D610 Modem Replacement, Battery: step 1, image 1 of 2 Dell Latitude D610 Modem Replacement, Battery: step 1, image 2 of 2
    • Remove the 3.9 mm Phillips #1 screw from the battery compartment.
  2. Dell Latitude D610 Modem Replacement: step 2, image 1 of 3 Dell Latitude D610 Modem Replacement: step 2, image 2 of 3 Dell Latitude D610 Modem Replacement: step 2, image 3 of 3
    • Locate the laptop battery release button lock
    • Push the battery release in the direction of the arrow, and pull upward.
  3. Dell Latitude D610 Modem Replacement: step 3, image 1 of 1
    • Remove the battery from its compartment.
  4. Dell Latitude D610 Modem Replacement, Modem: step 4, image 1 of 3 Dell Latitude D610 Modem Replacement, Modem: step 4, image 2 of 3 Dell Latitude D610 Modem Replacement, Modem: step 4, image 3 of 3
    • Remove the 3.9mm screw with a Philips #1 screwdriver containing the modem.
  5. Dell Latitude D610 Modem Replacement: step 5, image 1 of 2 Dell Latitude D610 Modem Replacement: step 5, image 2 of 2
    • Lift and remove the lid.
  6. Dell Latitude D610 Modem Replacement: step 6, image 1 of 2 Dell Latitude D610 Modem Replacement: step 6, image 2 of 2
    • Remove the 3.9mm Philips #1 screw on top of the modem.
  7. Dell Latitude D610 Modem Replacement: step 7, image 1 of 3 Dell Latitude D610 Modem Replacement: step 7, image 2 of 3 Dell Latitude D610 Modem Replacement: step 7, image 3 of 3
    • Pull on the white tab to remove the modem
    • Remove the cable going to the modem.
2 other people completed this guide.
Jose Chavez
122 Reputation
1 Guide authored
Cal Poly, Team 6-24, Maness Winter 2014 Member of Cal Poly, Team 6-24, Maness Winter 2014
CPSU-MANESS-W14S6G24
4 Members
5 Guides authored
One Comment
I have manufacturing mode problem can you help me??
Mod - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 1,663
