Dell Latitude D630 Hard Drive Replacement
  1. Dell Latitude D630 Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
    • Turn the laptop over so its bottom is facing you.
    • The laptop pictured comes with a palm rest attached to the battery case. This part may not be present on your laptop. Regardless, the steps are exactly the same.
  2. Dell Latitude D630 Hard Drive Replacement: step 2, image 1 of 1
    • Using two index fingers, slide the battery latches outward.
    • While still holding the latches out, use your thumbs to slide the battery out towards you.
    • Once the battery is dislodged, you can let go of the latches and remove the battery.
  3. Dell Latitude D630 Hard Drive Replacement, Hard Drive: step 3, image 1 of 3 Dell Latitude D630 Hard Drive Replacement, Hard Drive: step 3, image 2 of 3 Dell Latitude D630 Hard Drive Replacement, Hard Drive: step 3, image 3 of 3
    • Position the closed laptop upside down.
    • Unscrew the screw closest to the hard drive opening and the one diagonally to the right. This will loosen the hard drive.
    • Do not unscrew this screw!
  4. Dell Latitude D630 Hard Drive Replacement: step 4, image 1 of 1
    • Place thumb on the hard drive cover and get a firm grip.
    • Pull the hard drive out slowly to avoid any further damage to the laptop.
  5. Dell Latitude D630 Hard Drive Replacement: step 5, image 1 of 2 Dell Latitude D630 Hard Drive Replacement: step 5, image 2 of 2
    • Unscrew the screw on the right side to remove cover.
    • Slide cover off.
17 other people completed this guide.
Savi Chavan
979 Reputation
1 Guide authored
4 Comments
Dell latitude 2RHczd1
C Chandler - Reply
I appreciate the guide my good sir. Very helpful.
Matt Erti - Reply
Is the hard drive replaceable to 2.5-inch SSD? for example Kingston a400.
Aduh - Reply
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 28
All Time: 15,690
