Dell Latitude E4200 CMOS (CR2032 coin-cell time battery) Replacement
    • Remove the battery, LED cover and keyboard.
    • Pry up the coin-cell battery to release the double-sided adhesive tape on the bottom.
    • Lift the coin-cell battery out of the computer.
  1. Dell Latitude E4200 CMOS (CR2032 coin-cell time battery) Replacement, Disconnect the battery cable from the system board.: step 3, image 1 of 1
    • Disconnect the battery cable from the system board.
    • Connect the coin-cell battery cable to the system board.
  2. Dell Latitude E4200 CMOS (CR2032 coin-cell time battery) Replacement, Insert coin-cell battery into the computer.: step 5, image 1 of 1
    • Insert the coin-cell battery into the computer.
    • If you are re-installing the old coin-cell battery, press down to seal the tape on the bottom.
    • If you are installing a new coin-cell battery, remove the adhesive backing from the battery, and slide the battery under the tab. Press to seal the tape on the bottom.
    • Replace keyboard, LED cover, and battery.
Finish Line
Hezekiah Brown
6,169 Reputation
49 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
43 Members
1,985 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 11
All Time: 463
