Dell Latitude E4200 Keyboard Replacement
  1. Dell Latitude E4200 Keyboard Replacement, Power Button Panel: step 1, image 1 of 1
    • Open computer.
  2. Dell Latitude E4200 Keyboard Replacement: step 2, image 1 of 1
    • Slide any tool with a flat surface under the side bottom right corner of front panel and pry the front panel out of place.
    • A small flat head screwdriver would be an ideal tool to use during this step.
  3. Dell Latitude E4200 Keyboard Replacement: step 3, image 1 of 1
    • Once out of place, position your thumbs under the bottom of the panel and pull upwards.
  4. Dell Latitude E4200 Keyboard Replacement, Keyboard: step 4, image 1 of 1
    • Use a PH00 screwdriver to unscrew the screw.
  5. Dell Latitude E4200 Keyboard Replacement: step 5, image 1 of 2 Dell Latitude E4200 Keyboard Replacement: step 5, image 2 of 2
    • Use your hands to gently lift the keyboard from the device.
  6. Dell Latitude E4200 Keyboard Replacement: step 6, image 1 of 1
    • Gently turn the keyboard over.
  7. Dell Latitude E4200 Keyboard Replacement: step 7, image 1 of 1
    • Be careful not to disconnect the keyboard connector.
  8. Dell Latitude E4200 Keyboard Replacement: step 8, image 1 of 1
    • Use a flat head screwdriver to flip the keyboard connector up. This will allow you to disconnect the keyboard and remove it.
  9. Dell Latitude E4200 Keyboard Replacement: step 9, image 1 of 1
    • Completely lift the keyboard from the device, as they are now disassembled.
3 other people completed this guide.
Michelina Carbone
197 Reputation
1 Guide authored
Baylor, Team 5-6, Williams Spring 2015 Member of Baylor, Team 5-6, Williams Spring 2015
BU-WILLIAMS-S15S5G6
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 15
All Time: 4,312
