Dell Latitude E4310 MiniCard Replacement
  1. Dell Latitude E4310 MiniCard Replacement, Mini Card Door: step 1, image 1 of 3 Dell Latitude E4310 MiniCard Replacement, Mini Card Door: step 1, image 2 of 3 Dell Latitude E4310 MiniCard Replacement, Mini Card Door: step 1, image 3 of 3
    • Remove the single Phillips #1 screw.
    • This screw will not necessarily come off of the panel.
    • Lift up and remove with your fingernail, or a spudger, from the side of the door with the screw.
  2. Dell Latitude E4310 MiniCard Replacement, MiniCard: step 2, image 1 of 1
  3. Dell Latitude E4310 MiniCard Replacement: step 3, image 1 of 3 Dell Latitude E4310 MiniCard Replacement: step 3, image 2 of 3 Dell Latitude E4310 MiniCard Replacement: step 3, image 3 of 3
    • Use a spudger to pry up the card.
    • Pull the card up and out of its slot.
  4. Dell Latitude E4310 MiniCard Replacement: step 4, image 1 of 3 Dell Latitude E4310 MiniCard Replacement: step 4, image 2 of 3 Dell Latitude E4310 MiniCard Replacement: step 4, image 3 of 3
    • Pull the white and black antenna cables off of the card.
    • Make note of these connectors (mark with a marker or pen) as they must be the right connectors for the card to work properly.
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 19
All Time: 581
