Dell Latitude E5400 Memory Upgrade / Replacement
  1. Dell Latitude E5400 Memory Upgrade / Replacement, Remove battery: step 1, image 1 of 1
    • Be sure to remove the battery to prevent any electrical shortage.
  2. Dell Latitude E5400 Memory Upgrade / Replacement, Remove the backpanel: step 2, image 1 of 2 Dell Latitude E5400 Memory Upgrade / Replacement, Remove the backpanel: step 2, image 2 of 2
    • Losen all four screws and remove the backpanel.
    • Remove the backpanel with a spudger. Start out as in the second photo to prevent the plastic from breaking. Work you're way around the panel to remove it.
  3. Dell Latitude E5400 Memory Upgrade / Replacement, change/upgrade the memory: step 3, image 1 of 1
    • Now you can upgrade or change the memory.
    • NOTE: If the laptop doesnt boot after the upgrade, make sure the ram is fully inserted. Still doesnt boot? Try another memory stick.
Robin Koch
289 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 2,094
