Dell Latitude E5410 Hard Drive Replacement
  1. Dell Latitude E5410 Hard Drive Replacement, Battery Replacement: step 1, image 1 of 1
    • Have your Dell Latitude E5410 unit ready face down.
  2. Dell Latitude E5410 Hard Drive Replacement: step 2, image 1 of 1
    • Use your thumb to move the tab to the right that releases the battery, while using your other hand to slide the battery out.
    • The battery will come out straight toward you.
  3. Dell Latitude E5410 Hard Drive Replacement: step 3, image 1 of 1
    • Have your replacement battery ready to slide in.
  4. Dell Latitude E5410 Hard Drive Replacement, Remove the access panel: step 4, image 1 of 2 Dell Latitude E5410 Hard Drive Replacement, Remove the access panel: step 4, image 2 of 2
    • After removing the battery., loosen the screw(s) that secures the access panel to the computer, then that secures the access panel to the computer.
  5. Dell Latitude E5410 Hard Drive Replacement, Locate screws.: step 5, image 1 of 1
    • Locate and move the screws securing the hard drive to the computer.
  6. Dell Latitude E5410 Hard Drive Replacement, Remove hard drive from computer: step 6, image 1 of 1
    • Slide the hard drive towards the center of the computer and remove.
  7. Dell Latitude E5410 Hard Drive Replacement, Remove hard drive caddy: step 7, image 1 of 2 Dell Latitude E5410 Hard Drive Replacement, Remove hard drive caddy: step 7, image 2 of 2
    • Remove the screws securing the hard drive caddy to the hard drive. Then, lift up the hard drive caddy at an angle from the hard drive and remove.
With your replacement hard drive , reassemble your device by performing these instructions in reverse order.
Attached Documents
Aaron Thomas
1,194 Reputation
10 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
2 Comments
Hi Mr. Thomas
I am using Dell inspiration can I install Samsung MZ1LB1T9HALS-00007 in my system using this method?
carol james - Reply
Hi Aaron Thomas
I am using Dell inspiration 15 can I replace my hard drive Western Digital WD40EFRX using the same method?
Josh Roberts - Reply
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 15
All Time: 708
