Dell Latitude E5410 Screen Replacement
  1. Dell Latitude E5410 Screen Replacement, Dell Latitude E5410 Screen Replacement: step 1, image 1 of 1
    • Have your laptop ready with your screen pulled all they way down parallel to the bottom of the laptop.
  2. Dell Latitude E5410 Screen Replacement: step 2, image 1 of 1
    • Start on the top left or right corner of the screen edge and unscrew the small screws.
    • Be sure to remove the rubber placeholders in order to access the screws.
  3. Dell Latitude E5410 Screen Replacement: step 3, image 1 of 2 Dell Latitude E5410 Screen Replacement: step 3, image 2 of 2
    • Using a plastic opening tool, pry the bezel away from the screen.
  4. Dell Latitude E5410 Screen Replacement: step 4, image 1 of 2 Dell Latitude E5410 Screen Replacement: step 4, image 2 of 2
    • Use the Phillips screwdriver to remove the screws from corners around the screen.
  5. Dell Latitude E5410 Screen Replacement: step 5, image 1 of 1
    • Remove the screws from both sides.
    • Once removed, they will release the screen.
  6. Dell Latitude E5410 Screen Replacement: step 6, image 1 of 2 Dell Latitude E5410 Screen Replacement: step 6, image 2 of 2
    • Use the spudger to move the sensor aside.
  7. Dell Latitude E5410 Screen Replacement: step 7, image 1 of 2 Dell Latitude E5410 Screen Replacement: step 7, image 2 of 2
    • Release the screen by pulling up and out.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 2,620
