Dell Latitude E5410 keyboard Replacement
  1. Dell Latitude E5410 keyboard Replacement, Dell Latitude E5410 keyboard: step 1, image 1 of 1
    • Position laptop so that the LCD screen is aligned directly flat and parallel to the keyboard section of the laptop.
  2. Dell Latitude E5410 keyboard Replacement: step 2, image 1 of 1
    • Use the iFix it Opening Tool to remove the flat section located directly above the keyboard, as seen in picture.
  3. Dell Latitude E5410 keyboard Replacement: step 3, image 1 of 1
    • Locate two internal screws (pictured) under removed section.
    • Use the Phillips screwdriver to remove both screws.
    • The screw in the middle is 3.85mm and the screw on the left is 8.66mm.
  4. Dell Latitude E5410 keyboard Replacement: step 4, image 1 of 1
    • Firmly grip the upper section of the keyboard.
    • Pull on the keyboard in an upwards motion.
    • The keyboard should be successfully removed.
3 other people completed this guide.
One Comment
thanks man but its super easy not moderat i have 16 years old and i remove my keybord...
ZendomXGamer ZXG - Reply
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 29
All Time: 5,172
