Dell Latitude E5500 Bluetooth Card Replacement
  1. Dell Latitude E5500 Bluetooth Card Replacement, Bluetooth Card: step 1, image 1 of 1
    • Unscrew the single 3.5mm Phillips #1 screw that holds on the bottom plate of the device.
  2. Dell Latitude E5500 Bluetooth Card Replacement: step 2, image 1 of 2 Dell Latitude E5500 Bluetooth Card Replacement: step 2, image 2 of 2
    • Place your hands on the plate and pull it toward yourself.
    • The plate will pop out of place and may then be removed.
  3. Dell Latitude E5500 Bluetooth Card Replacement: step 3, image 1 of 2 Dell Latitude E5500 Bluetooth Card Replacement: step 3, image 2 of 2
    • The Bluetooth card is located near the front of the device, and is the expansion card with one antenna attached to it.
  4. Dell Latitude E5500 Bluetooth Card Replacement: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Remove the wire connecting the card to the laptop with a pair of tweezers.
  5. Dell Latitude E5500 Bluetooth Card Replacement: step 5, image 1 of 1
    • Unscrew the 4mm Phillips #1 screw that secure the card in place.
  6. Dell Latitude E5500 Bluetooth Card Replacement: step 6, image 1 of 2 Dell Latitude E5500 Bluetooth Card Replacement: step 6, image 2 of 2
    • After completing steps 4 & 5, the card will lift up at an angle as shown.
    • Once the card has popped out of place, it can be gently removed.
4 other people completed this guide.
Richard Harrison
805 Reputation
4 Guides authored
UMass Dartmouth, Team 2-4, Isaacson Fall 2016 Member of UMass Dartmouth, Team 2-4, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G4
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 28
All Time: 2,478
