Dell Latitude E6230 12.5" HD (1366x768) Anti-Glare WLED-backlit Replacement
  1. Dell Latitude E6230 12.5" HD (1366x768) Anti-Glare WLED-backlit Replacement, Remove Battery: step 1, image 1 of 2 Dell Latitude E6230 12.5" HD (1366x768) Anti-Glare WLED-backlit Replacement, Remove Battery: step 1, image 2 of 2
    • Slide the release latches to unlock the battery.
    • Remove the battery from the computer.
  2. Dell Latitude E6230 12.5" HD (1366x768) Anti-Glare WLED-backlit Replacement, Removing the Display Bezel: step 2, image 1 of 3 Dell Latitude E6230 12.5" HD (1366x768) Anti-Glare WLED-backlit Replacement, Removing the Display Bezel: step 2, image 2 of 3 Dell Latitude E6230 12.5" HD (1366x768) Anti-Glare WLED-backlit Replacement, Removing the Display Bezel: step 2, image 3 of 3
    • Pry the top edge of the display bezel.
    • Work your way along to the sides and bottom edge of the display bezel
    • Remove the display bezel from the display assembly
  3. Dell Latitude E6230 12.5" HD (1366x768) Anti-Glare WLED-backlit Replacement, Removing the Display Panel: step 3, image 1 of 3 Dell Latitude E6230 12.5" HD (1366x768) Anti-Glare WLED-backlit Replacement, Removing the Display Panel: step 3, image 2 of 3 Dell Latitude E6230 12.5" HD (1366x768) Anti-Glare WLED-backlit Replacement, Removing the Display Panel: step 3, image 3 of 3
    • Remove the 6 (M2 x 3mm) screws that secure the display panel to the display assembly
    • Flip the display panel over
    • Peel off the LVDS cable connector tape and disconnect the LVDS cable from the display panel
    • Remove the display panel from the display assembly
alarson118
553 Reputation
3 Guides authored
Tech-zone Member of Tech-zone
Business
2 Members
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 6
All Time: 150
